C4D教程-创建展台 - 菜鸟C4D
C4D教程-创建展台
 热度: 136 [ 复制链接 ]
首页 › 分类资源 › C4D教程 发布时间:2017-7-7 20:52 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
10070
152
Cinema 4D Tutorial How to Create an Exhibition StandSo something that’s come up quite a few times on our videos, is the request to show how to model an exhibition stand.
As I explain in the video, this is something that is both relatively simple and tricky at the same time.
Modelling something like that isn’t too difficult, not having a specific design to model from, is the trickier part.
Once you’ve been allocated an exhibition space, normally you’d have an idea of the sort of layout you want, the sort of stuff available to you, the sort of stuff you could afford and you’d pop that all over to a designer who’d do the rest.
In this video, I have taken features from a few bespoke exhibition stands and given some tips and tricks on how you could model your own.
Firstly you will start by figuring out your space by using a cube and making it the correct size.
Then you will use some textures from Cinema 4D’s content browser to add the floor.
You will then learn how to use splines and an Extrude NURBS in order to create the back archway.
You will use a simple cube and the bend deformer in order to add the front desks and upper struts.
Using splines and extrudes or simple cubes you can give yourself the back of the stand and the front panel.
Then you will learn how to apply some textures, correctly size them and then scale them to fit your model.
Simple, clean textures allow the stand to “stand” out as it were and then using extra content from the browser you can fill your stand with other things like chairs and TV’s.
Adding in simple lights, a physical sky, some luminent polygons and of course, Global Illumination and Ambient Occlusion, finalise your stand.
2017年7月7日发布
教程时常:53.44 大小:403.89MB
教程百度网盘:
上一篇:C4D教程-咖啡杯建模
下一篇:CINEMA 4D教程——模拟车轮和轮胎
今天坐到了沙发,心情不错,感觉挺好的。
2017-7-8 08:22
非常棒!希望楼主能分享更棒的资源出来
2017-7-8 09:06
非常棒!希望楼主能分享更棒的资源出来
2017-7-8 09:22
非常棒!希望楼主能分享更棒的资源出来
2017-7-8 09:40
谢谢楼主的分享!!!期待更多好资源
2017-7-8 17:17
很不错的资源,感谢楼主分享,感谢楼主分享
2017-7-9 13:46
非常棒!希望楼主能分享更棒的资源出来
2017-7-10 07:36
很想学,今天就看到,谢谢楼主辛苦。
2017-7-10 09:32
试试看这个,网上的汉化版装了以后都还是英文的
2017-7-10 14:53
