支持系统:Windows(32位和64位版本)的Mac OS X(Intel或PPC)MAXON Cinema 4D的无缝集成全自动匹配移动 非常快的多线程跟踪引擎,它采用4处理器格式:JPEG,PNG,GIF CIN的,DPX,PNM,TGA,TIFF,BMP图像序列任意图像分辨率,包括SDTV和HDTV高达2048x1156灵活的自动功能检测选项解决了自由和节点泛相机的议案解决了常量和变量的焦距拍摄镜头失真校正工具多边形的面罩工具丰富的场景建模工具快速方便地访问现场方向**工具在需要的地方添加手动点可控出口的三维点和场景中的对象数量导出图像序列的镜头失真补偿 - 导出的图像序列可以自动场景背景进口 系统需求为了能够兼容大多数计算机系统,CineCAT是设计具有较低的系统要求。
Feature Overview
* Supported systems: Windows (32 and 64 bit versions), Mac OS X (Intel or PPC)
* Seamless integration into MAXON Cinema 4D
* Fully automatic match moving
* Very fast multi-threaded tracking engine, which employs up to 4 processors
* Image sequences in the format: JPEG, PNG, GIF, CIN, DPX, PNM, TGA, TIFF, BMP
* Arbitrary image resolution including SDTV and HDTV up to 2048x1156
* Flexible Auto Feature Detector options
* Solves free and nodal pan camera motion
* Solves constant and variable focal length shots
* Lens distortion correction tool
* Polygon mask tool
* Extensive scene modelling tools
* Fast and easy access to scene orientation
* Locator tool for adding manual points where needed
* Controllable number of exported 3D points and scene objects
* Export of image sequences with compensated lens distortion - exported image
sequences can be automatically imported as scene backdrops
