C4D阿诺德Arnold渲染器 SolidAngle C4DtoA 2.1.1 R17/R18/R19 Win/Mac AMPED+替换XX版 C4DtoA 2.1版本开始不再支持C4D R16,增加支持C4D R19,如果安装后C4D 打不开,请先卸载插件,然后把C4D更新到最新版本,最后重新安装插件即可
全新的2.0版本,使用Arnold 5.0.1.3 核心,新增加多种Shader材质,VR摄像机,OSL shader,灯光等大量功能和性能提升
功能增加: Support added for the LOD object in CINEMA 4D R19
性能提升:
Add ‘connect shaders’ command to the network editor
Add ‘create reference’ command to the network editor
Add shortcut to setup a displacement and viewport root shader
Duplicate a shader with its inputs in the network editor
Add mute & solo mode to the Light Manager
Add selected lights to a newly created group in the Light Manager
Edit all selected lights in the Light Manager
Bug修复:
Wrong layout in the Light Manager when closing a light group in the tree
Texture is locked in the Team Render client
Memory leak in Turbulence FD
Crash when translating a mesh light while Arnold IPR is running
Crash when the IPR is docked in a custom layout
Frontal projection is wrong in indirect
