C4D材质插件 PBR材质转换脚本 1.0 CV-Convert to PBR Material V1.0
Works with Release: R19+
Easily switch from simple color materials to a reflectance-based workflow.
Converts selected color + spec materials to the "New PBR Material" template.
Useful for updating imported materials (via FBX, OBJ, etc) to something that is more Cinema 4D R19 friendly.
Limited support for updating "Reflection (Legacy)" single reflectance layers to PBR.
Known Limitations
No support for Animated parameters.
Specular -> Reflectance and back again is lossy.
Fresnel won?t match source if you?re using a Fresnel shader
