C4D插件 样条补丁汉化版 Spline Patch 3.02 - 菜鸟C4D
 热度: 340 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2018-4-12 16:40 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
21194
355
C4D插件 样条补丁汉化版 Spline Patch 3.02SplinePatch generates surfaces from three or four splines. It is designed as an object generator and works fully parametric.
The MultiPatch welds several Spline Patches to one smooth surface and rounds outer edges with an editable profile.
The new SplineCage object creates and manages all connections between the splines of a cage and generates all desired surfaces with just one mouse click.
SplineCage
The main new feature of version 3.0 is the new SplineCage object. Once again, it has become much faster and easier to generate patch objects. In patch modeling, all splines defining the object to be modeled, make the spline cage. The new object works as a generator and creates stable connections at the intersections of all splines of the cage. These connection points can be moved and are retained even when editing the single splines.
The preview options displays all the surface, that can be generated from the cage. With a click, real patch objects are created, optionally subordinated to a MultiPatch object.
Tri-Patch from quadrangles
There are some reasons to avoid triangles in modeling. Until now Tri-patches were always created from triangles. Optionally, Tri-patches can now be generated from quadrangles, if the number of subdivisions is even.
MultiPatch symmetry
The MultiPatch obejct has been enhanced by a symmetry option. The benefit in comparision to the symmetry object is that the symmetry is applied before generating the outer edge profiles. Thus, there are no problems with profiles at the mirror plane.
New parameter for edge profile
The U profile of the outer edges has been enhanced by the parameter "Length". It is used to extend the inner part of the "U".
Integrated help system
The context sensitive help is now available via the plug-ins menu und is displayed in a window within Cinema 4D.
C4D样条曲线创建曲面补丁建模插件中文汉化版 Spline Patch V3.04支持C4D R25-R26
https://www.c4dcn.com/thread-37036.html
上一篇:C4D渲染器插件 阿诺德2.3.0 Solid.Angle.Cinema4D.To.Arnold.v2.3.0.For.Cinema4D.R19-AMPED
下一篇:C4D插件2016年度合集 Cinema4D Plugin Collection Jan 2016 by n0mad
菜鸟C4D论坛和你一起从零开始!
2018-4-12 17:02
菜鸟C4D论坛和你一起从零开始!
2018-4-12 17:04
菜鸟C4D论坛和你一起从零开始!
2018-4-12 17:12
菜鸟C4D论坛和你一起从零开始!!!!!!!!!!!!!!!!!
2018-4-12 17:18
66666666666666666666666666666666666666666666666666666666666
2018-4-12 17:22
菜鸟C4D论坛和你一起从零开始!菜鸟C4D论坛和你一起从零开始!
2018-4-12 17:24
2018-4-12 18:24
将此回复同步到 腾讯微博 | 回帖后跳转到最后一页
2018-4-12 18:36
C4D插件 样条补丁汉化版Spline Patch v2.51.1附带教程
2018-4-12 18:43
