RealFlow 2.5.3流体插件汉化版 NextLimit RealFlow C4D 2.5.3.0083 R17-R19 - 菜鸟C4D
 热度: 653 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2018-6-12 23:12 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
31072
706
C4D插件 RealFlow流体插件 NextLimit RealFlow C4D 2.5.3.0083 R17-R19 Win
General
- Array Tool: Parameters can't be animated for meshes.
- Initial State files created in RealFlow | Cinema 4D 1.0 are not compatible with 2.0 version due to the switch from RPC to Alembic.
Emitters
- When using a multi-segment spline with the spline emitter node the "Prev" and "Next" buttons only iterate through the control points on the current segment.
Meshing
- Mesh fluid/emitter weight vertex map computation is limited to a maximum amount of 10.
Parameters
-358 - File paths can't have unicode characters on Mac OS X.
-519 - Simulation steps configuration from RealFlow | Cinema 4D 1.0 scenes is reset to Auto mode when opened in 2.0 version.
Rendering
- Simulation look on render may differ between multiple simulation/renders unless caching is enabled.
- Objects deformed with Rigid, Elastic and Particle Skinner only support motion blur when using the Point Cache tag.
- Particle render instances are not rendered/recognized by NVIDIA's Iray.
- Motion blur with meshes doesn't work with NVIDIA's Iray.
- Motion blur with meshes doesn't work with Maxwell Render.
- Particle render instances original objects remain visible during render.
Fixed bugs - Caching
- Cinema 4D crashes on caching if the cache folder field is empty.
- Animated cache offsets do not work in render time.
Daemons
- Setting the same fluid as source and target in a Filter daemon freezes Cinema 4D.
- Attractor daemon "Internal Radius", "External Radius" and "Planet Radius" parameters should have units.
- Attractor viewport representation does not match its behavior when Attenuated is enabled.
Rendering
- Mesher vertex maps don't work with Octane render. (Version 3.08 of Octane plugin fixes the issue).
- There is a one frame offset when rendering meshes with motion blur enabled.
Save and Load
- Particle UVs are not loaded in cache mode.
Parameters
- It is possible to type negative values for scene simulation steps and iterations.
Known bugs
Emitters
- Emitter ID value is not preserved on scene reopening.
Splines
- If a segment is removed the configuration of the circles of the other segments is reset.
- Undo/Redo is not working when a control point is added.
Daemons
- Having two or more k Isolated daemons linked to the same fluid makes the isolation value grow as many times as the number of k Isolated linked daemons.
上一篇:更新支持R19:MAXtoC4D v4.01XX版
下一篇:C4D Octane渲染器摄影棚灯光预设汉化版 PLKv1.2 by Mitch Myers | PRODUCTION LIGH...
2018-6-12 23:15
抢沙发66666666666666666666666666
2018-6-12 23:22
2018-6-12 23:25
抢沙发66666666666666666666666666抢沙发66666666666666666666666666抢沙发66666666666666666666666666
2018-6-12 23:32
2018-6-13 00:05
2018-6-13 02:31
nffffffffnsssssssssssssssssssssssssss
2018-6-13 04:06
下来试试能不能装成下来试试能不能装成
2018-6-13 06:56
感谢分享了哦
2018-6-13 07:51
