C4D绑定动画插件:Select N'Go v2.0 for Cinema 4D - 菜鸟C4D
 热度: 247 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2018-6-20 09:14 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
17459
262
F.C.S Select N'Go v2.0 for Cinema 4D by Field Creators Studios
What is Select N'Go?
Select N'Go export the selected object/s from your project scene to your custom directory.
Select N'Go Takes Exporter allows you to export FBX, ABC, DAE animation clips takes on the
selected object from your scene in multi file output. Select N'Go Takes Exporter is basically
the Game Exporter that is inside Autodesk Maya.
Features:
- Updated: Select N'Go v2.0
        * New UI changes.
        * Import is back.
        * Open export folder after export.
        * Recent export folder is added.
- Updated: Select N'Go Takes Exporter v2.0
        * New UI changes.
        * Save Data of your project as presets.
        * Added 60 Takes Slots.
        * Multi Component Export.
        * More Export Formats been added (.FBX | .ABC | .DAE).
        * Added play button added to play each clip take.
        * Open export folder.
        * Message Log as been added.
System requirements
PC or Mac capability of running the versions of Cinema 4D
Versions Latest R15.064, R16, R17, R18, R19
# NOTE! Always run Cinema 4D as administrator.
Installation Guide:
1*     Open Cinema 4d and go Edit -> Preferences and at the bottom Left
        of Preferences window its a  button call Open Preferences Folder.
                                or
                If you prefer in in the main Maxon folder.
            Example: C:\Program Files\MAXON\CINEMA 4D R16\plugins
2* Open the plugins folder.
    NOTE!!! Any Previously FCS Folder: FCS Tools, FCS_Tools or FCS-C4D-ToolBox Package folder
    please delete.
3* Now Copy the new F.C.S-C4dToolset folder from the unzip file that is in the plugins folder and paste
    it inside the plugins folder.
4* Restart Cinema 4D, Startup CINEMA 4D
什么是选择N‘Go?
选择N‘Go采取出口商允许您导出FBX,ABC,DAE动画剪辑从您的场景在多文件输出的选定对象。
选择N‘Go采取出口商基本上是游戏出口商内的Autodesk Maya。
优化说明:
*保存您的项目的数据作为预置。
*选择N’Go采取出口商v2.0
*新UI更改。
*保存您的项目的数据作为预置。
*增加了60个插槽。
*多个组件导出。*
添加了更多的导出格式(.FBX.abc.DAE)。
*添加了播放按钮来播放每个剪辑拍摄。
*打开导出文件夹。
*添加了最新的导出文件夹。
*添加了消息日志。
系统要求始终以管理员身份运行Cinema 4D。
安装指南:
1、在主要的Maxon文件夹中。例如:C:\ProgramFiles\Maxon\File4DR16\plugins 2*打开插件文件夹。
注意!任何以前的FCS文件夹:FCS工具、FCS_Tools或FCS-C4D-工具箱包文件夹请删除。
2、现在从插件文件夹中的解压缩文件中复制新的F.C.S-C4dToolset文件夹,并将其粘贴到plugins文件夹中。
3、重新启动Cinema 4D
C4D多格式模型资产批量导入导出插件中文汉化版 FCS Select N' Go v3.5
上一篇:unfold3d9.02汉化单文件绿化版
下一篇:C4D Vray渲染器插件 V3.6 R18/R19 Win/Mac
没用过 感觉很牛x 感谢分享!!!
2018-6-20 15:02
感谢汉化 感谢分享!!!!!!!!!!!!!!!!!
2018-6-20 09:18
没用过 感觉很牛x x x x x x x x x !
2018-6-20 09:27
2018-6-20 09:37
2018-6-20 09:42
2018-6-20 10:37
2018-6-20 11:17
楼主体验过这个东西吗? 有木有做出作品来
2018-6-20 16:09
谁都别拦我,我要回帖攒金币,我要换购vip!
2018-6-20 16:56
