本模型是由Turbosquid机构出品的钢铁侠3D模型合辑,Turbosquid Iron Man Rigged,大小:10 MB,格式:max jpg,包含各种姿势与动作的钢铁侠模型。
Model is rigged and already joined to CharacterStudio Biped and ready for any animation.
Comes with detailed normal maps and color map textures.
Suitable for games and sims, detailed enough for close-up renders.
Originally modelled in 3ds max 8.
The 3ds max zip file contains also vray and standard materials scenes.
Features:
- High quality polygonal model – correctly scaled accurate representation of the original objects.
- Model resolutions are optimized for polygon efficiency (in 3DS MAX the meshsmooth function can be used to increase mesh resolution if necessary).
- All colors can be easily modified.
- Model is fully textured with all materials applied.
- All textures and materials are included and mapped in every format.
- Max models grouped for easy selection & objects are logically named for ease of scene management.
- No part-name confusion when importing several models into a scene.
- No cleaning up necessary, just drop model into your scene and start rendering.
- No special plugin needed to open scene.
