Modo材质预设 金属 木材 塑料 编织物布料 - 菜鸟C4D
精选材质 Modo材质预设 金属 木材 塑料 编织物布料
 热度: 525 [ 复制链接 ]
首页 › 分类素材 › C4D材质 发布时间:2018-10-6 22:30 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
22864
544
VizPack:产品是160多种材质的集合,提供一系列详细和物理上精确的着色器,以满足不同的需求。专注于产品渲染,此系列中的材质是通用材质,代表可视化工作所需的清洁,无瑕疵材质。未来包装中将会出现磨损和损坏的材质,但重点在于新材质中非常详细的材质着色器。
这些材质是多年研究的结果,使用测量数据和视觉参考来创建最准确和最真实的材质。这些材质的设计从远处和近距离看都很好,当你放大它们时,细节层就会变得明显。此系列中提供的材质比默认情况下随Modo提供的材质更加详细和一致,并且可以在高质量渲染中获得更好的效果。
从金属,木材,织物和塑料,您可以找到适合各种不同类型项目的材质,既可以按原样使用,也可以作为进一步定制的起点。
通过使用此库,您可以从阴影和纹理中消除猜测,因为您知道这些材质都使用物理上准确的值并且基于实际参考。
这些材质还与Adam O'Hern创建的Tagger套件兼容。
请注意,这些材质设计用于Modo的本机渲染器 - 如果有足够的兴趣,可以创建Vray和Octane版本。
VizPack: Products is a collection of over 160 materials providing a range of detailed and physically accurate shaders to cover many different needs. With a focus on product renders the materials in this collection are general purpose materials representing the clean, unblemished materials required for visualisation work. Worn and damaged materials will feature in future packs, but the emphasis here is on highly detailed shaders of materials in new condition.
These materials are the result of years of research, using both measured data and visual references to create the most accurate and realistic materials possible. The materials are designed to look good both from a distance and in close-up, with layers of detail that become apparent when you zoom in on them. The materials on offer in this collection are more detailed and consistent than those that ship with Modo by default, and will give better results in high quality renders.
From metals, to woods, fabrics, and plastics, you will find materials to suit many different kinds of projects, either to use as they are, or as starting points for further customization.
By using this library you can take the guesswork out of shading and texturing, knowing that the materials all use physically accurate values and are based on real-world references.
The materials are also compatible with the Tagger kit created by Adam O'Hern.
Please note that these materials are designed for use with Modo's native renderer - Vray and Octane versions may be created if there is enough interest.
上一篇:Substance材质包 Substance Care Package Vol.2
下一篇:[23G]VRAY渲染器材质合集包 VRScans (New Release)
首页 › 分类素材 › C4D材质 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
是对方过后就哭了;立刻就会功夫的萨对方过后就哭
2018-10-10 09:55
这么好的东西没人下嘛,啦啦啦啦啦啦啦啦啦
2018-10-7 21:14
解放路的撒速度快分反对撒撒旦发射点发
2018-10-10 10:47
努力升级 获得资格 努力加油666666666666
2018-10-10 13:11
真是难得的好东西,希望楼主能分享更棒的资源出来。
2018-10-10 15:03
qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
2018-10-12 10:56
真好,下载下载。真好,下载下载。真好,下载下载。真好,下载下载。
2018-10-12 12:05
111111111111111111111111111111111111111111111111111111
2018-10-13 15:10
来直接使用了RealFlow for C4D这个插件。非常不错的教程,小白可以跟跟
2018-10-15 13:47
