Cinema 4D快速生成链条插件中英对照汉化版附教程 C4DZone Chain Generator 1.0 - 菜鸟C4D
 热度: 128 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2014-9-23 17:24 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
13579
128
C4D R16插件:快速生成链条C4DZone Chain Generator 1.0 MUS3
Cinema4D release R13/14/15/16
-OSX Snow Leopard or greater
-Windows 7 32/64 bit or greater
Chain Generator 是一个Cinema R13/14/15/16插件,帮助用户创建并单击激活任何一种机械连锁。绘制一个开放的样条在前视图,点击创建链按钮,现在在花键点模式尝试连接与拖链。
Chain Generator is a Cinema 4D R13/14/15/16 plugin that helps user to create and animate any kind of mechanical chain with one click.Draw an open spline on the front view, click on Create Chain button and now in spline point mode try to connect the chain with drag and drop.Once the chain is closed you can press play and the chain start to spin.You don't have to take care about Xpresso and the rigging, plugin do it for you and create controller for adjust the chain speed rotation.Of course the chain is fully parametric, you can customize the ring type or model a new one and use it.You can have fun with the plugin creating chainsaw, tank chain, bicycle chain and much more.The plugin works with all editions of Cinema 4D R13/14/15/16 (Prime, Broadcast, Visualize, Studio) and with all cinema 4D compatible engine renderers (V-Ray etc).
安装方法
Chain Generator 1.0+ChainGenerator_KG放入C4D插件目录
打开C4D在插件列表里找到chain generator-Keygen打开
生成注册码 如下图
然后执行重载插件即可出现注册窗口 如下图
注册完 重启C4D即可
上一篇:C4D插件 转换关键帧中英对照汉化版 Nitro4D NitroBake v1.0.0 Cinema 4D
下一篇:[R13-16]草丛绘制插件 C4DZone Grass Painter 2.0 for Cinema4D
谢谢  谢谢 白哥了   谢谢  谢谢 哈哈
2014-9-23 17:27
白大师汉化的真快,辛苦了!!!!!!
2014-9-23 17:27
非常感谢,谢谢你的分享!非常感谢,谢谢你的分享!
2014-9-23 20:25
白大师汉化的真快,辛苦了!!!!!!
2014-9-23 21:23
不错,谢谢分享啊!~~~~~~~~~~~~~~~~~~~
2014-9-23 21:40
谢谢楼主分享!!!!!!!!!!!!!!!
2014-9-24 07:16
汉化了,感谢辛苦汉化给大家,谢谢分享
2014-9-24 11:16
收藏了,谢谢,太感谢了。。。。。。
2014-9-24 18:47
太好了,这么好的插件,谢谢分享
2014-9-24 23:31
