DirectControl enables you to control objects and parameters using a game controller
直接控制使你控制对象和参数使用游戏控制器
The tag plugin DirectControl enables you to control objects and parameters using a game controller. E.g. you can control a camera via joystick or you can drive a car through your scene while the animation is running. Things that can't be done using the built-in functions can be realized with XPresso — the controller data are output continuously.
标签插件直接控制使你控制对象和参数使用游戏控制器。例如,您可以通过操纵杆或你可以开车穿过你的场景在动画运行控制摄像机。事情做不使用内置的函数可以用XPresso -控制器的数据输出连续实现。
Heyne Multimedia DirectControl for Cinema 4D Game Controller Support
海涅多媒体CINEMA 4D的游戏控制器支持的直接控制
