C4D渲染器VRAY插件R20版 渲染器3.6 Chaosgroup Vray for R20 3.6.0 180829 Win - 菜鸟C4D
 热度: 380 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2018-11-12 23:31 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
21562
398
C4D渲染器VRAY插件R20版 渲染器3.6 Chaosgroup Vray for C4D R20 3.6.0 180829 WinInfo:
QUALITY
V-Ray comes with all the lighting, shading, and rendering tools you need to create professional, photoreal imagery and animation.
POWER
Built to handle your biggest projects and your toughest scenes. Render anything and everything with V-Ray.
SPEED
Spend less time waiting and more time being creative. Deliver your best work and never miss a deadline, via CPU or GPU, local or via the network.
CREATIVE CONTROL
V-Ray puts you in the driver seat. You’re in control. With V-Ray’s versatile features, you can choose the best approach for your scene.
DEEP C4D INTEGRATION
V-Ray’s very deep C4d integration keeps your workflow fluid and smooth and combines best of both worlds [C4D & V-Ray]
AN INDUSTRY STANDARD
Independent artists and top studios choose V-Ray every day to create world-class designs and visual effects.
NEW V-RAY 3.6 CORE – BLAZING FAST CPU & GPU RENDERING SPEED
In V-Ray 3.6 all parts of the engine have been greatly sped up. The new extremely optimized CPU rendering brings V-Ray to speeds never seen before rendering, providing a feature full and powerful production toolset for high-quality, high-resolution images and animations with V-Ray. V-Ray provides 100% physical correct ray tracing methods. In addition, V-Ray 3.6 now also offers blazing fast GPU render options for previews and final frame rendering (for supported features-see FAQ page).
SIMPLE USAGE – NEW FULL AUTOMATIC SAMPLING
Simplicity is one of the best new features. V-Ray 3.6’s new automated sampling with its variance based adaptive ray tracing technology offers a dramatically different way to work for artists in eliminating the need to set or tune any complex settings – just choose the GI engine type, the render time and start rendering. Subdivisions, technical render settings, all that is not needed any more in V-Ray 3.6. The new progressive rendering for CPU and GPU gives you an instant feedback on the render result.
GLOBAL ILLUMINATION & ACCURATE LIGHTS
V-Ray uses physically-correct ray tracing methods to precisely calculate lights and reflected light (“GI”) as we see it in reality. You can choose from several global illumination options – precise path tracing, approximate or a hybrid of both.
PHYSICAL LAYERED BRDFS WITH NEW MATERIALS & SHADERS
V-RAYforC4D offers a real world & multi-layered BRDF for creating high end and physical correct materials. Due to its real-world layering setup, it is automatic full energy preservation correct. Special BRFD Material types gives you the all the tools and Artist can wish for.
PHYSICAL CAMERAS – VR READY – 360 DEGREE STEREO CAMERAS
V-Rays real-world camera system let you work like a photographer, it offers all physical control and provides detailed depth of field and cinematic motion blur. The new VR 360 stereo camera types let you output to the newest VR technologies.
UNLIMITED UV’S PER SHADERS & TRIPLANAR MAPPING
Our new UV manager Tag brings UV channels to C4D. This allows you to use unlimited UVs per shader for comprehensive UV mapping control. The new Triplanar mapping feature enables an artist-friendly workflow to proper map models which have no UV map at all.
PROXIES & INSTANCING WITH SHADER & MATERIAL RANDOMISATION TOOLS
Render massive scenes with proxy objects. V-Ray proxies efficiently replace complex scene geometry and load only at render time. Via random variation shaders and materials, you can control variations in colour and texture to the proxies or render instances.
NEW SKY MODES, AREAL PERSPECTIVE & FASTER VOLUME RENDERING
V-Ray offers several realistic sky models for realistic lighting of outdoor and indoor scenes, including Hosek sky with atmospheric haze. The volume environment fog renders faster now and is also available on per material basis, to make clouds, fog, volume light, god rays etc.
FULL MAXON HAIR, FUR, SPLINE AND GRASS RENDER SUPPORT
V-RAYforC4D fully supports Maxon Hair via real 3d geometry using V-Ray’s memory efficient hair procedurals. The V-Ray Hair BRDF gives physical correct Hair shading. Effects like base colour sampling, root tip colour & transparency, are supported. Also included is V-RayFur and V-Ray FastFur.
NEW VFB WIN & OSX – LUT CONTROL, DENOISER & LENS EFFECTS
The advanced VFB offers high-level tools, like colour correction, exposure, white balance, LUT support, History, V-Ray lens effects and the new V-Ray denoiser tool which can greatly speed up your renders. It is available on Windows and OSX.
NEW V-RAY CLIPPER, RENDER TIME BOOLEANS & RENDER MASK
V-Ray 3.6 offers a real-time clipper which lets you cut any geometry, even proxies multiple times, making architectural section renderings of big buildings a breeze with it. It also has an option to use custom geometry for render time booleans. Each Vray BRDF has a raytraced rounding option for automatic edge chamfering, for enhanced realism. The new Render mask tool lets you mask out any region of the render by various methods.
CPU & GPU PRODUCTION RENDER & NEW IPR PREVIEW WINDOW
V-Rays famous production render options have been further enhanced in speed and features. Beside the very fast and powerful CPU production renderer, we offer now the option to use also GPU for production for the GPU supported features(for features/limits- see FAQ page). In the new IPR window, you can preview your scene in CPU or GPU mode. Also, VFB lens effects and denoiser add GPU acceleration to your renders.
NEW EXTENDED RENDER ELEMENTS, ID PASSES AND LIGHT SELECT FEATURE
V-Ray 3.6 offers an extensive set of render elements and object/material id selection channels via its multipass feature for professional post-production pipelines. It also supports now to have selected lights on separate layers, for changing colour or intensity later on via post editing tools.
V-RAY DR & FULL UNLIMITED C4D CMD-LINE/TEAMRENDERING
V-Ray is designed from the core to render on distributed systems. It offers native V-Ray Distributed rendering (DR) with free DR nodes included. Dr supports CPU and GPU rendering and allows you also to render only on nodes, excluding the local machine. In addition, we support Maxon Team/Cmd line render for stills and animations, with unlimited free nodes included!
安装方法:
Win:
  • 拷贝VrayBridge_R20_V3_clean_180829文件到C:\Program Files\MAXON\Cinema 4D R20\plugins目录下
  • 打开C4D,会提示VRayForC4D的序列号错误,打开注册机xf-vray.exe,输入C4D的序列号,点击Generate,将生成的许可文件放到C4D的根目录即可,比如C:\Program Files\MAXON\Cinema 4D R20
  • 重启C4D即可
上一篇:C4D实时交互破碎脚本工具 CV-Paint Fracture in Cinema 4D v1.00.01
下一篇:C4D渲染器插件 VRAY 3.7.001 DEMO FOR WIN/MAC
感谢分享这么好的资源!下载下来学习一下
2018-11-13 09:17
精品不止于眼前,菜鸟C4D交流论坛!
2018-11-13 09:31
本帖隐藏内容需要等级至少 R11,请在底部回复后即可浏览,您当前等级为 R15
2018-11-13 09:40
精品不止于眼前,菜鸟C4D交流论坛
2018-11-13 13:46
真是难得的好东西,希望楼主能分享更棒的资源出来。
2018-11-13 14:09
感谢分享这么好的资源!下载下来学习一下
2018-11-13 15:39
感谢分享这么好的资源!下载下来学习一下
2018-11-13 16:07
6f5r感谢分享这么好的资源!下载下来学习一下
2018-11-14 09:48
网页无法打开是怎么回事 网页打不开
2018-11-14 14:52
你好,我是菜鸟4D交流论坛站长!
作用分类: 渲染器 » VRAY » 3.6X
插件分类: 插件
支持(高版本自测): R19 R20
支持语言: 英文
出现位置: 插件菜单 材质通道 标签菜单 渲染设置 其他
检索码: CN201811122331
