XP调整样条教程 - 菜鸟C4D
XP调整样条教程
 热度: 70 [ 复制链接 ]
首页 › 分类资源 › C4D教程 发布时间:2014-11-8 09:44 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
4668
70
XP调整样条教程Align to spline is no doubt an expression that most Cinema 4D artists will have used at some time or another. The problem with the built in expression is that it is clamped and you can only animate the position parameter from 0% to 100%. If you want the object to loop or wrap around the spline it is not so simple.
对齐曲线无疑是一个表达式,大多数CINEMA 4D的艺术家将用在某个时间。与内置的表达问题是卡只能动画的位置参数从0%到100%。如果你想要的物体的循环或包绕花键就不是那么简单。
There are other solutions available within the application, you could use MoGraph and clone onto a spline. Then use the offset parameter. However in this tutorial, I show you how to build a loopable align to spline expression using just Xpresso. The advantage here is you can use this setup with the most basic install of Cinema4D and also the object is still in it’s original state as it hasn’t been passed through a generator.
还有其他的解决方案可在应用程序中,您可以使用Mograph克隆到一个样条。然后用偏移参数。然而在本教程中,我向您展示了如何构建一个loopable对齐只使用XPresso样条函数表达式。这里的好处是你可以使用这个设置最基本的安装Cinema4D以及对象仍然是在它的原始状态,因为它没有被通过一个发电机。
I show you how to include a tangential option and the addition of a pop-up menu to define the axis you would like to align.
我告诉你如何包括切线选项的弹出菜单定义轴要对齐的加入。
Anyway enough of my waffle. Check out the tutorial below or click through and watch it over on the helloluxx channel on Vimeo
无论如何,足够我胡扯。看看下面的教程或点击观看了在Vimeo helloluxx通道
上一篇:C4D电视包装视频教程 CG Tuts+ Premium Create a TV Ident Using Cinema 4D R14's ...
下一篇:[第一期]菜鸟C4D中文商业教程:电风扇建模+XP表达式绑定动画(建模部分/含工程)
谢谢你的无私分享 再次感谢世界有你真好
2014-11-10 12:25
感谢楼主分享姿势
2014-11-12 14:06
x-p   最近在学习x-p啊      大量需求教程  加油谢谢
2014-11-18 14:22
感谢楼主分享姿势    ,我对表达式不明白,正好学习一下
2014-11-25 15:43
顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶
2015-1-12 23:30
教程很好,谢谢楼主分享~~~~~~~~~~~~~~~~~~~~~~
2015-5-17 20:10
谢谢你的无私分享 再次感谢世界有你真好
2015-7-19 15:36
谢谢分享!!!!!!!!!!!!!!!!!!!!!!
2015-10-20 09:31
楼主我要跟你生猴子你知道吗!!!
2016-1-26 15:37
