OBJ Sequence Exporter 2.0 for C4D R20 - 菜鸟C4D
 热度: 410 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2019-2-17 16:19 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
22133
419
用于Cinema 4D的OBJ Exporter是一个插件,用于从Cinema 4D导出OBJ文件序列,您可以使用它们使用Plexus OBJ对象将其导入Plexus。
新功能:
导出器现在导出所有顶点属性,如法线和纹理坐标。它还会创建.mtl文件,如果不需要,可以将其丢弃。
兼容性:
用于Cinema 4D的OBJ Sequence Exporter 2.0与R17.055及更高版本兼容。用R18,R19和R20测试
支持:
如果您遇到与Plexus中的OBJ序列相关的问题,请联系我们以获得快速响应。如果它与其他与Plexus无关的插件/应用程序有关,请联系该程序的发布者以获得解决方案。
重要的提示:
此插件旨在与Plexus配合使用。它可能适用于其他产品/插件,但不能保证。
更新日志:
OBJ Sequence Exporter v2.0
发行日期:2019年1月21日
  • 添加了对更多Vertex属性和MTL文件的支持
  • 针对R20进行了更新
安装说明
解压缩zip文件并将内容移动到Cinema 4D的插件目录中。您可以从File-> Export-> OBJ Sequence导出OBJ序列。
OBJ Exporter for Cinema 4D is a plug-in that exports OBJ file sequences from Cinema 4D, which you can use them to import into Plexus using the Plexus OBJ Object.
What's new?
The exporter now exports all vertex attributes like Normals and Texture Coordinates. It also creates .mtl files which can be discarded if not needed.
Compatibility:
OBJ Sequence Exporter 2.0 for Cinema 4D is compatible with R17.055 and above. Tested with R18,R19 and R20
Support:
If you are having issues related to OBJ Sequences in Plexus contact us for a quick response. If it's related to other plug-ins/applications not related to Plexus please contact the publisher of that program for a solution.
Important Note:
This plug-in is designed to work with Plexus. It might work with other products/plug-ins, but there is no guarantee.
Changelog:
Release Date: Jan 21 2019
Added Support for more Vertex attributes and MTL files
Updated for R20
Installation Instructions
Extract the zip file and move the contents in to the plug-ins directory of Cinema 4D. You can export the OBJ Sequences from File->Export->OBJ Sequence.
上一篇:HB Modeling Bundle中文汉化包+中文官方文档(10.8版本) BY YORHA_4D
下一篇:炫云2019新年特惠活动
2019-2-17 20:46
666666666666666666
2019-2-17 22:48
这是个不错的插件菜单,谢谢分享!!!!
2019-2-17 23:18
谢谢························································
2019-2-18 08:01
2019-2-18 09:27
2019-2-18 09:37
2019-2-18 09:49
本帖隐藏内容需要等级至少 R11在底部回复后才可浏览,您当前等级为 R15
2019-2-18 09:51
不知道有没有教程,试了一下,输出的objPlexus不认,好像和19那个版本不是一回事,就不知道有没有相关的教程
2019-2-18 09:52
