讲解C4D动力学模拟的基本设置,不同物体之间碰撞的动态效果,包括和运动图形学板块里一些效果器的配合使用等
Learn how to create dynamic simulation setups, and how to use alternative methods to achieve more control and work around the limitations.
When dealing with Dynamic simulations, it’s not uncommon to use a Standard Particle or Thinking Particle emitter, to emit dynamic objects. Although by default, it’s a very simple setup, it has some drawbacks and limitations. In this series, I’ll begin by showing you how to create these setups, and then I’ll show you how to use alternative methods to achieve more control and work around the limitations.
