C4D教程 制作VJ师风格绚丽多彩场景教程On this class you will learn some simple techniques to create a colorful abstract poster using Photoshop and Cinema4D.You will create an abstract shape on cinema4D and then upload it on photoshop to make color fixing, adding other elements and finally creating a modern luminous artwork.During the following of the class you can experiment with different options or levels as the process is more experimental and it gives you the freedom to explore and get different results.
