C4D预设 几何切片分段生成预设 Geometry Slicer In Cinema 4D - 菜鸟C4D
 热度: 326 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2019-4-23 23:49 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
16427
317
This tutorial shows you a quick and easy way to create a geometry slicer in Cinema 4D. We also have a prebuilt rig that you can download to make this process even easier for you. Simply drop your object into the Voronoi Fracture and then adjust the parameters to suit your requirements.
The technique is actually really simple, we take a linear spline with only two points and use this as the source for the Voronoi Fracture. By using a spline as the source, you can adjust the number of points created along the spline length, this controls the number of slices generated.
上一篇:阿诺德渲染器插件双语汉化 Arnold渲染器XX版 SolidAngle C4DtoA 2.5.0 R18/R19/...
下一篇:C4D插件 绳子生成插件汉化版 HoRope master
和发动机卡视角发货单拉会发生了黑粉来撒会
2019-4-24 02:00
2019-4-24 09:19
2019-4-24 09:22
2019-4-24 11:23
2019-4-24 11:42
2019-4-24 19:07
精品不止于眼前,菜鸟C4D越来越棒~~~!!!
2019-4-25 09:22
111111111111111111111111111111111111111111111111111111111
2019-4-25 14:17
......35652295594894984984195418941561431..3.
2019-4-25 14:56
