1.The open source script was developed by Bloomingshade.
此免费开源脚本是由Bloomingshade在业余时间随意开发的。
2.If you click the script,you will find an 'input dialog' window appears on your screen.Just enter the name so that the objects you've selected will be renamed. 当你点了这个脚本,一个输入框会弹出来,只要输入名字,你选择的对象就会自动被重命名。
3.But notice that whether you click 'OK' or 'Cancel', the effects are the same: your objects will be renamed, but fortunately, you can undo/redo it. 但是请注意,无论你是点了'确定'还是'取消'。效果都是一样的,你的物体都会被重命名,然而幸运的是,你可以撤销/重做。会有这种机制是因为脚本是我随便写的。
4.If you enter 'slod:' at the beginning of the name, it means: rename the selected objects in selected order, if not, by default, the selected objects will be renamed in top-down order. 如果你在输入名称前,先输入'slod:',注意此处的冒号必须是英文字符,那么你选择的物体将会以被选择时的顺序重新命名,否则将以默认的方式根据对象列表中的排列顺序,从上到下依次重命名。
5.By default, a number will be added to the end of the name you've entered, but if you include '*', the asterisk in the characters you entered, things will change, the symbol '*' will be replaced by the number. 在默认情况下,一个数字编号会被附加到你输入的名字的末尾,但如果你输入了星号'*',事情就不一样了,星号会被数字编号所替换。
6.If you enter 'help()', notice that () is not the number zero, it's a pair of parentheses, you will see me, a How-to document! 如果你输入'help()',注意此处()是一对括号,为英文字符,你就可以看到本帮助文档!
安装方法:将文件解压到X:\Program Files\MAXON\CINEMA 4D R1X\library\scripts 脚本目录,,,注意不是插件目录哈
