C4D教程 用于Cinema 4D的Corona渲染器中的天空对象 - 菜鸟C4D
 热度: 89 [ 复制链接 ]
首页 › 分类资源 › C4D教程 发布时间:2019-12-23 08:00 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
4693
86
In this tutorial, learn about the new Sky object in Corona Renderer 5 for Cinema 4D, and how it can be used to get multiple different environments in one render for use in LightMix!
00:06 - Introduction
00:17 - Adding a Corona Sky object to the scene
00:42 - The Physical Sky type
01:22 - The Simple Color type
02:03 - The Visibility section
02:55 - The Shader/HDRI type
03:10 - Using an HDRI
05:06 - Not recommended, but you can follow the previous workflow as shown here
06:23 - Using Shaders, e.g. Gradient
07:02 - Introduction to using multiple Corona Sky objects (for LightMix)
07:42 - Setting up the LightMix for multiple Skies (HDRIs)
08:55 - Disable the Adaptive Light Solver (only when using multiple Skies in LightMix!)
09:55 - Using the LightMix with multiple Skies (HDRIs)
11:46 - Example final images from LightMix with multiple Skies (HDRI)
12:41 - Using multiple Skies (Physical) with LightMix
14:07 - Example final images from LightMix with multiple Skies (Physical and HDRI)
14:30 - Remember to allow enough time or passes for noise to clean up
15:15 - Linking Corona Suns and Corona Skies
17:24 - Using the native Cinema 4D Background object
17:58 - Remember to disable Visible Directly for the Corona Sky when using a Background object
18:35 - Thanks for watching!
上一篇:Octane渲染器制作三维角色建模材质渲染C4D教程
下一篇:Octane渲染器金属银质手表建模材质渲染C4D教程
积极交流学习 严禁恶意灌水积极交流学习 严禁恶意灌水
2019-12-23 08:57
菜鸟C4D,与你一起从零开始...C4DCN.com
2019-12-23 09:35
2019-12-23 09:42
人是铁饭是钢,一天不玩C4D蛋疼的慌!
2019-12-23 09:44
支持楼主继续分享优秀资源,消灭零回复!
2019-12-23 10:01
不错,真的太棒了,感谢楼主的分享!
2019-12-23 10:32
2019-12-23 10:43
2019-12-23 11:33
2019-12-23 13:12
