C4D秋天树木环境场景建模渲染教程 Helloluxx learn Cinema 4D Tutorial Natural En... - 菜鸟C4D
精选教程 C4D秋天树木环境场景建模渲染教程 Helloluxx learn Cinema 4D Tutorial Natural En...
 热度: 246 [ 复制链接 ]
首页 › 分类资源 › C4D教程 发布时间:2015-1-27 10:15 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
16757
269
helloluxx学习。CINEMA 4D教程:从Marijn raeven自然环境
Creating a detailed natural environment in Cinema 4D is no easy task - trees and other foliage can be hard to work with, consuming hours of render time and destroying scene performance. It can also be difficult to create a convincing natural look with enough variation and irregularity.
创建一个在CINEMA 4D的详细的自然环境是不容易的任务树和其他植物可以是艰苦的工作,耗费工时的渲染时间和破坏的现场表现。它也可以是难以建立一个令人信服的自然看起来有足够的变化和不规则。
This training series for Cinema 4D focusses on the creation of a detailed and realistic forest. In a total of 12 chapters, the series guides you through the entire process from start to finish - no steps are skipped, no fast-forwarding. The final result is a large, detailed forest that remains responsive in the viewport and can be rendered in a matter of minutes.
本系列培训4D影院致力于创建一个详细的和现实的森林。在共12章,该系列将引导您完成整个过程从开始到结束没有步骤被省略,没有快进。最终的结果是一个大的,详细的森林仍然响应在视口,可以在几分钟内呈现。
The tree models used in the training come from the free plant kit from Laubwerk. Instructions on how to install this plugin are included with the training.
用于训练来自laubwerk免费植物盒树模型。说明如何安装这个插件包括与训练。
Marijn has animated the first few shots of this introductory video so that you may see another aspect of just how beautiful your end results could be upon completing the learn. Natural Environments training. Please note however that animation is not included as part of this training title.
动画介绍视频Marijn这几次投篮,你可能会看到另一个方面是多么美丽的你的最终结果可能是在完成学习。自然环境下训练。请注意,动画是不包括在这个培训标题部分。
The four renders below are the final result of this training. These renders were completely generated inside Cinema 4D, without colour correction, in an external application such as Photoshop.
四,下面是这次培训的最终结果。这使得完全生成的四维影院内,没有色彩校正,在外部应用程序如PS图象处理软件。
Minimum Requirements
最低要求
This training series was recorded with Cinema 4D R16 Studio. R15 Studio owners should be able to follow most of the training as well, with the exception of the new Reflectance channel.
这一系列培训与CINEMA 4D R16录制工作室。R15工作室业主应该遵循的训练一样,随着新的反射通道异常。
For users who already own the Laubwerk Plant Kit, please ensure you are using the latest Laubwerk plugin (1.0.12 at the time of publishing) to ensure compatibility the supplied scene files. To check the version you are using, choose About from the Laubwerk menu.
对于那些已经拥有laubwerk植物工具包,请确保您使用的是最新的插件(1.0.12 laubwerk在出版时间)以确保兼容性提供的场景文件。检查你正在使用的版本,选择从laubwerk菜单。
The course is divided into the following chapters:
本课程分为以下章节:
CHAPTER 01 - 11:48 - Terrain
01章- 48 -地形
CHAPTER 02 - 15:57 - Terrain textures
02章- 15:57 -地形纹理
CHAPTER 03 - 23:50 - Trees
03章- 23:50树
CHAPTER 04 - 27:20 - Leaves
04章- 27:20叶子
CHAPTER 05 - 24:21 - Waterside
05章- 24:21 -水边
CHAPTER 06 - 14:48 - Tilable leaves textures
06章- 14:48 - tilable叶子纹理
CHAPTER 07 - 30:20 - Leaf distribution
07章:30:20叶分布
CHAPTER 08 - 25:54 - Lighting using the physical sky
08章利用物理天空照明25:54
CHAPTER 09 - 31:07 - Shading
09章:31:07遮阳
CHAPTER 10 - 13:43 - Distant environment
10章- 13:43遥远的环境
CHAPTER 11 - 26:01 - Camera setup
11章:26:01相机设置
CHAPTER 12 - 26:18 - Finishing touches
12章:26:18 -收尾
The total runtime for this training series is 4 hours and 31 minutes.
这一系列培训的总运行时间为4小时31分钟。
上一篇:C4D+AE 字母创意演义教程VFXBro - Fresh FX-After Effects and Cinema 4D Advanced...
下一篇:在C4d内创建读秒倒计时
这个我觉得好难学呀。
2015-1-27 11:30
这不是我等屌丝能学会的- -
2015-1-27 11:50
C4D秋天树木环境场景建模渲染教程  【大神在带路】
2015-1-27 11:53
好棒!!!!!!!!!!!!!!!
2015-1-27 12:02
这个我觉得好难学呀。       。。。。。。。。。
2015-1-27 12:13
感谢楼主的无私分享,这么好的资源必须得顶啊
2015-1-27 12:24
这个不错,学习下得~~~~~~~感谢楼主的无私分享
2015-1-27 13:21
好东西,真要试试才行
2015-1-27 15:21
2015-1-27 15:52
