C4D建模教程-复杂结构科幻飞船钢铁机械大门布线卡边
这是在Cinema 4D中模拟科幻爆炸门外框的七个视频(总运行时间约为3个小时)中的第一个。 本教程介绍使用细分曲面(SDS)进行硬表面建模。 几年前,我在Cinema 4D R14中录制了这些视频,但它们仍然适用于旧版本和更新版本的Cinema 4D。
This is the first of seven videos (total running time app. 3 hours) on modeling the outer frame of a scifi blast door in Cinema 4D. This tutorial is about hard surface modeling with subdivision surfaces (SDS). I recorded these videos some years ago in Cinema 4D R14, but they still apply to both older and newer versions of Cinema 4D.
