5个案例教会你认识OC渲染器使用过程的小经验C4D教程
Most 3D rendering engines have some similarities in terms of setup and workflow. Of course, there will be some, one of which is Octane Render. Some settings are unique to the OC renderer because it is a GPU renderer. In this C4D video tutorial, Dave Bergin from cgshortcut explained five common problems and solutions for Octane Render, which will help you render better when using the Cinema 4D renderer from Otoy. Including the reflection and reflection of smooth glass materials, light passing through glass, noise texture, how to save a lot of memory and double-sided materials.
大多数三维渲染引擎在设置和工作流方面有一些相似之处。当然,会有一些,其中之一是辛烷渲染。由于OC渲染器是GPU渲染器,因此某些设置是唯一的。在这个C4D视频教程中,cgshortcut的Dave Bergin解释了辛烷值渲染的五个常见问题和解决方案,这将有助于您在使用Otoy的Cinema 4D渲染器时更好地渲染。包括对光滑玻璃材料的反射和反射,光线通过玻璃,噪声纹理,如何节省大量的记忆和双面材料。
Octane Render 4 is the world's first GPU-accelerated fastest, unbiased, physical renderer. This means Octane uses your computer's graphics card to render photorealistic images, and it's super fast. With Octane's parallel computing power, you can create amazing effects.
辛烷渲染4是世界上第一个加速最快,无偏,物理渲染GPU。这意味着Octane使用计算机的显卡渲染真实感图像,而且速度非常快。有了辛烷的并行计算能力,你可以创造出惊人的效果。
