Nitro4D has released a free Cinema 4D tool. MagicTextureMap lets you easily load and use texture map folders in a single shader.
Nitro4D发布了一个免费的C4D插件。MagicTextureMap允许您在单个着色器中轻松加载和使用纹理贴图文件夹。
MagicTextureMap will look for images under which you can select a directory. Once you have the folder path set, MagicTextureMap will load all the images in that folder. You can see them all in a group, you can select and use textures in a shader.
MagicTextureMap将查找可以在其中选择目录的图像。设置文件夹路径后,MagicTextureMap将加载该文件夹中的所有图像。您可以在一个组中看到它们,也可以在材质球中选择和使用纹理。
You can have a single shader transform the texture map. In C4D plug-in, you can set key frames for texture animation.
可以使用单个材质球变换纹理贴图。在C4D插件中,可以为纹理动画设置关键帧。
This demo shows the tools used to create a character's mouth animation, showing how great MagicTextureMap can be in some cases.
这个演示展示了用于创建角色嘴巴动画的工具,展示了MagicTextureMap在某些情况下有多棒。
NitroMan pointed out that you can also make more progressive things with shaders if you mix filter layers.
NitroMan指出,如果混合使用过滤层,也可以使用着色器进行更渐进的操作。
