10组高质量精度汽车轮毂轮胎C4D模型
所有型号均包含FBX文件格式,可在支持FBX的任何软件中轻松使用。 还带有Maya场景文件,该文件在一个场景中包含所有网格物体。 其他文件格式可根据要求提供。
Pack还包含一个展开的轮胎模型,一个胎面位移图+法线图以及4k分辨率的自定义侧壁纹理
A pack of 10 high quality wheel/rim models. Use this for personal or commercial projects or just crack open the unsmoothed files to check out the geometry. Comes with UVs so go ahead and slap on those textures!
All models are in FBX file format for easy use in any software supporting FBX. Also comes with a Maya scene file that has all the meshes in one scene. Other file formats available on request.
Pack also contains one unwrapped Tyre model, a displacement map + normal map for the tyre tread, and a custom sidewall texture in 4k resolution
