00:00:00 - Intro
00:00:32 - Inspiration: Corridor Crew
00:02:45 - Get access to a full set of modeled dominoes on
00:3:54 - Setting up a simple set of dominoes with a spline and cloner
00:13:43 - Replacing gravity with our own with some basic Field Forces
00:16:02 - Second set of dominoes on the wall, and adding to the Field Force
00:24:34 - Building a structure to transfer dominoes up the wall naturally
00:31:59 - Inside of a cylinder or simple spiral
00:48:57 - Getting fancy. Twisting a Helix around an custom spline
00:58:00 - Spiraling around the OUTSIDE of a twisting Helix
01:03:22 - Different gravity wells, using masks
01:08:52 - Make it your own! Very important
