C4D教程-华丽栏目包装文字叠加多层动画 Cinema 4d Tutorial Letter ident - 菜鸟C4D
 热度: 102 [ 复制链接 ]
首页 › 分类资源 › C4D教程 发布时间:2020-6-22 11:16 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
5983
105
In this Cinema 4d Tutorial | Letter ident part 1,
I talk about how I set up the object like cubes, letter, and tell you the important of coordinate axis of each objects.
n this Cinema 4d Tutorial | Letter ident part 2 Mograh and Camera,
I will show you about the *Mograph of object by using effector push apart
*The animation of camera by using the morph camera
In this Cinema 4d Tutorial | letter ident part 3 Lighting and Material,
I show you how I
set up the light, and create material for my object. I put it in the layer and turn on each lights and objects and show you step by step.
n this Cinema 4d Tutorial | Letter ident part 4 ( Rendering), I show you about
how I set up before I render my artwork out.
The importance is about : object buffer, multi pass, renderer, and effect you turn on.
In this part 5A, I show you how I compose my artwork that render from cinema 4d into after effect. There are many steps to correct the color and make it better. Dont forget to watch part 5B!
n this Cinema 4d Tutorial | Letter ident part 5B (Compositing),
I show you about
-technique composting and how I create background and use some cool effect in after effect!
在此Cinema 4d教程中|信件识别码第1部分
我将讨论如何设置诸如立方体,字母之类的对象,并告诉您每个对象的坐标轴的重要性。
此Cinema 4d教程|字母ident第2部分Mograh和Camera,
我将通过使用效应器推开向您展示对象的* Mograph
*使用变形相机的相机动画
在此Cinema 4d教程中|字母标识第3部分“照明和材料”,
我告诉你我如何
设置灯光,并为我的对象创建材质。我将其放在图层中,并打开每个灯光和对象,并逐步向您展示。
此Cinema 4d教程|身份证明书第4部分(渲染),我向您介绍
在渲染图稿之前如何设置。
重要性在于:打开对象缓冲区,多遍,渲染器和效果。
在第5A部分中,我将向您展示如何将我从电影院4d渲染到后效的作品进行合成。有许多步骤可以校正颜色并使颜色更好。不要忘记看5B部分!
此Cinema 4d教程|字母标识部分5B(合成),
我告诉你
技术堆肥以及如何创建背景并在后效中使用一些很酷的效果!
上一篇:C4D教程-摄像机变形旋转动画 Cinema 4d Tutorial | Camera Morph
下一篇:C4D教程-多维数据网格地板发光浮动动画 Cinema 4d cube grid floor animation
2020-6-22 11:16
2020-6-22 11:16
2020-6-22 11:16
2020-6-22 12:37
2020-6-22 13:02
2020-6-22 14:03
2020-6-22 16:36
2020-6-23 17:47
2020-6-28 15:51
