X-Particle粒子插件创建沙子LOGO演绎C4D动画教程在此Cinema 4D教程中,我们将使用X-Particles来创建沙子。 在沙滩上,我们将露出一个徽标。 沙子中有运动,这是由一系列位移图创建的。 我们用顶点贴图和场控制位移贴图。 这种位移驱动X-Particles设置中的粒子。 为了获得沙子的外观,我们需要使用很多颗粒。 最终结果是有150万个粒子。 但是渲染速度很快。 我使用Redshift作为渲染引擎。 使用Cinema 4D内部的字段总是很高兴。 它是如此强大。
In this Cinema 4D tutorial, we'll use X-Particles to create sand. In the sand, we'll reveal a logo. There's movement in the sand, which is created by a series of displacement maps. We control the displacement maps with vertex maps and fields. This displacement is driving the particles in the X-Particles setup. To achieve a look of sand, we need to use a lot of particles. In the final result, there are 1.5 million particles. But it renders quite quickly. I used Redshift as the render engine. It's always a pleasure to work with fields inside of Cinema 4D. It's so powerful.
