根据排渣方式的不同,煤气炉可分为内部排渣和外部排渣两种方式。 由于传输方式的不同,炉渣气的产生器可分为涡轮炉和蜗杆出渣和水力棘轮式出渣两种。 通常使用这两种排渣方法。
According to the different ways of slag discharge, the gas furnace can be divided into two ways: internal slag tapping and external slag discharging. Due to the different transmission modes, the slag gas producer can be divided into two types: turbine and worm slag tapping and hydraulic ratchet slag tapping. These two slag tapping methods are commonly used.
