Real Book V.1.1
Create your book with all the pages you want, adjust the size, the animation, rotate the base, flip through a page one at a time, and much more.
New features in version 1.1:
New Animation Tab
Enable Automatic Animation = enables the automatic animation mode
Animation = sets the grow of the total animation.
Overlap = sets the amount of overlap between the animations of consecutive pages.
Enable Add Overlap Variation
Add Overlap Variation = the spline defines an additional positive Overlap during the Animation. Be careful because it's easy to introduce intersection between pages.
****Add pages****
To add pages you need to perform some steps:
1. Duplicate one or more pages using Control-drag or the Duplicate function in C4D.
2. Make sure that the order is correct.
3. Open the main XPresso Tag and Click on the big node with green header.
4. On the Attribute Manager抯 Node Properties page there is a box with the current pages inside. Drag the new pages in the box and keep all the pages in the correct order.
5. Done!
In this preset there are two places where you can make modifications.
If you click on the main Real Book object you can see the first one on the Attribute Manager, the Control Tab.
Another Tab for the single page control is visible when you click the Page object that you need to modify.
***Page Control***
Turn = turn the page between 0 and 180 sessadecimal degrees.
Fine Adjustment = this control is useful when you need a different posing position for a single page or a group of pages.
***Book Control***
Base Turn 1 = rotate the base edge 1 between 0 and 90 sessadecimal degrees.
Base Turn 2 = rotate the base edge 2 between 0 and 90 sessadecimal degrees.
Bending Base Dimension = set the average length of radius bend when the page rotates.
Incremental Bending Base = set the variation amount of the Bending Base Dimension along the base from the first to the last page.
Landing = set the pose position when the page is turned and BaseTurn1=100% and BaseTurn2=0.
Torsion Force = set the maximum force of the second animation bend (I should name it the alive Bend).
Torsion Rotation = set the rotation of the second animation bend.
Torsion Force Distribution = the spline defines the variation of Torsion Force during the page rotation.
Torsion Rotation Distribution = the spline defines the variation of Torsion Rotation during the page rotation.
