防毒面具包括3D Hazmat核,细菌,化学危害NBC服,以高精度建模。 这是我发现的几个参考之间的混合。 该模型已在3d高多边形中精确重建,以保留每个细节。
您需要的质量:
首先,该模型基于几张图片并关闭了实际产品,以提供最佳的纹理参考和比例质量。
整个模型的纹理都取决于参考和实际产品。 解压缩纹理文件后,可能需要重新放置纹理。
Gas Mask Included 3D Hazmat nuclear , bacteriological , chemical hazard NBC suit modeled in high precision. this is a mix between several references i found. this model has been accurately recreated in 3d High poly to keep every details.
The Quality you need :
First of all, this model was based on a several pictures and close up of the real product to provide you the best quality in terms of texture references and proportions.
The entire model was textured with its accessories relying on references and actual products. Textures may need to be relocate after uncompressing the Texture file.
格式包括:
C4D
高多边形模型+ GAS MASK,可细分。
4K纹理。
3ds Max,V射线(带纹理的)
3ds Max,Corona(带纹理)
搅拌机,周期(纹理的)
FBX(仅网格)
OBJ(仅网格)
