灰猩猩系列-C4D摄像机焦距变形教程Choosing The Correct Focal Length - 菜鸟C4D
 热度: 107 [ 复制链接 ]
首页 › 分类资源 › C4D教程 发布时间:2015-3-10 14:54 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
10011
107
Many 3D artists never bother changing the default focal length of their camera. However, choosing the right “lens” makes a huge difference when setting up the composition and feeling of your scene. There is a rich language of film and photography that you can use to make your renders look and feel the way you want them to.
Learning even a bit about traditional photography or composition can do wonders for your final renders. Below are a few rules to get you started in the right direction when picking the right focal length for your scene.
Wide Angle Lenses (15-35mm) Make Things Look…
Large
Impressive
Powerful
Looming
Overwhelming
Telephoto Lenses 85-300mm) Make Things Look…
Small
Fun
Cute
Far Away
Weak
Attractive
You should combine these rules with the angle of the camera. As a general rule, if you want the hero of your scene to appear large, try looking UP at it. The opposite is the same. Looking down on objects make them look small and cute. Or, lonely and sad.
许多3D艺术家从来没有改变他们的相机默认的焦距。然而,选择合适的“镜头”,使一个巨大的差异在建立成分和感觉。有丰富的电影和摄影的语言可以让你呈现的外观和感觉你想要的方式。
即使学习一点关于传统摄影或组合物可以激发你的最终呈现。下面是一些规则,让你开始在正确的方向时,选择合适的焦距为你的场景。
广角镜头(15-35mm)使事情看起来…
大
令人印象深刻的
强大的
迫在眉睫
压倒性的
长焦镜头85-300mm)使事情看起来…
小
有趣的
可爱的
远
弱
有吸引力的
你应该把这些规则与相机的角度。作为一般规则,如果你想你的场景的英雄大量出现,试图寻找它。相反的是一样的。俯视对象使他们看起来小巧可爱。或者,孤独和悲伤。
上一篇:灰猩猩系列-C4D快速创建地形教程Fast Topographies in Cinema4D Tutorial
下一篇:灰猩猩系列-C4D制作名片教程:建模、变形、照明、渲染
咱网站资源太棒啦!C4DCN.com真好!
2015-3-10 14:57
2015-3-10 15:04
数数真的就是正好不够十五个字!
2015-3-10 15:06
数数真的就是正好不够十五个字!
2015-3-10 15:06
谢谢LZ分享好教程 学学学
2015-3-10 15:33
非常感谢楼主分享!!!!!!!!!!
2015-3-10 17:36
好厉害的样子。。。。。。。。。。。。。。。。。。。。。
2015-3-13 14:37
好东西!!!!!!!!!!!!!!!!!!!!!!!!
2015-3-18 14:07
看看。谢谢分享。谢谢楼主分享。
2015-4-16 17:21
