AE+PS制作电影阿凡达悬浮山场景特效合成教程 Animate a Composite Image in After Effects
在PS中,将图像分层,然后导入到AE中。 在AE中,对图层进行动画处理以产生3D场景效果
了解如何拍摄在Photoshop中制作的图像,导出多个图层,在After Effects中导入和组织这些图层,然后创建具有平滑运动和相机运动的3D场景。 如果您是Photoshop大师,这是将脚趾伸入After Effects美好世界的好方法!
Learn how to take an image made in Photoshop, export out multiple Layers, import and organize those Layers in After Effects, and then create a 3D scene complete with smooth motion and camera movement. If you’re a Photoshop guru, this is a great way to dip your toes into the wonderful world of After Effects!
