C4D玻璃杯破碎子 弹时间特效教程 - 菜鸟C4D
C4D玻璃杯破碎子 弹时间特效教程
 热度: 132 [ 复制链接 ]
首页 › 分类资源 › C4D教程 发布时间:2015-3-10 16:55 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
8580
134
在这个系列教程中,您将学习如何创建一个很酷的慢动作将使用CINEMA 4D动画和后玻璃的影响。在这庞大的演讲过程中,专业画家西里尔kotecky会教你的插件和工作动力和创造这样一个镜头是什么情况。好处包括前即可以在早期阶段为你挡住你的镜头时,摄像机的位置。
你会开始学习如何使用Adobe Illustrator可以作为建模工具,它是如何强大的3D预览功能,可以用来微调之前移动到三维模型的外观。从这里到4D影院,西里尔将通过设置场景,压裂玻璃使用Xplode插件如何制作动画,以及**的冲击结合使用手键动画和Mograph物理。如何解决问题,当事情没有按预期。
在以后的课程中你将学习如何创建逼真的材料,安装一个动态的照明装置,产生焦散和多通道渲染工作。你会得到一个详细的如何真实世界摄像机的工作,和同样的原则适用于工作在3D。最后,你要做的事的最终合成动画在Adobe After Effects和了解再定时,色彩校正,运动模糊和景深场,加上丰富的其他有用的提示和技巧。
In this tutorial series you'll learn how to create a cool slow-motion shattering glass animation using Cinema 4D and After Effects. Over the course of this massive lecture, professional artist Cyril Kotecky will teach you the ins and outs of working with dynamics and what goes into creating such a shot. Including the benefits Pre-Viz can have in the early stages as you block out your shot timing and camera positions.
You'll start by learning how Adobe Illustrator can be used as a modeling tool and how it's powerful 3D previewing capabilities can be used to fine tune the look of your model before moving into 3D. From there it's into Cinema 4D where Cyril will take you through setting up the scene, fracturing the glass using the Xplode plugin, and how to animate the bullet's impact using a combination of hand keyed animation and MoGraph physics. And how to problem solve when things don't go as expected.
In later lessons you'll learn how to create realistic materials, setup a dynamic lighting rig, generate caustics and work with multi-pass rendering. You'll get a detailed breakdown of how real world cameras work, and how the same principles apply to working in 3D. Finally, you'll wrap things up by compositing the final animation in Adobe After Effects and learn about re-timing, color correction, motion blur and depth of field, plus a wealth of other useful tips and tricks.
上一篇:C4D雪山背景文字片头演义教程Snow Mountain Titles with Element 3D and Cinema 4D
下一篇:C4D创建米字旗徽章别针纽扣教程Tutorial: How to Create Button Badges
2015-3-10 17:02
看看,C4D玻璃杯破碎子弹时间特效教程
2015-3-10 21:35
C4DCN.com给你全面的教程插件模型资源!我觉得C4DCN.com是注册对了!
2015-3-11 08:34
这个效果真是太棒了。
2015-3-11 09:17
谢谢。。。。。。。。。。。。。。。。。。。。。。。。。。
2015-3-11 18:57
可以吧时间缩短着放的话一定很厉害的样子
2015-4-6 16:41
好棒!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
2015-4-6 17:16
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
2015-5-11 15:56
C4D玻璃杯破碎子弹时间特效教程
2015-5-18 09:15
