DisableMaterials灯光检测插件 - 菜鸟C4D
 热度: 91 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2015-3-25 09:51 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
7541
89
这是一款可以把场景中所有的材质转为最基础的模型本身材质,可用来测试场景灯光的明暗关系是否满足你的渲染需要,从而大大的降低了传统的有材质的渲染时间(如果你只是想测试光影关系的话)正式渲染的时候只要取消基础材质显示就可以正常渲染了。
Disable Materials
Features
Disable (and re-enable) all Materials in your scene.
Version 1.20 adds the option to disable and re-enable only selected materials. To disable specific materials first select them in the Material Manager and then use the "Disable Selected Material" menu entry.
Materials are disabled by restricting them to a selection that starts with "off#".
If a selection already exists for the material tag then "off#" is prepended to the selection name. Otherwise a selection named "off#" is created. When enabling materials again the "off#" is removed again.
Compatibility
This plugin requires Cinema 4D 9.1 because it makes use of the enhanced COFFEE syntax with '#' - operator introduced with Release 9.1
Open Source
The source code is included under an open source (MIT style) license. See the plugin source file (.cof) for details.
Disclaimer
The software is provided "as is", without warranty of any kind, express or implied, including but not limited to the warranties of merchantability, fitness for a particular purpose and noninfringement. In no event shall the authors or copyright holders be liable for any claim, damages or other liability, whether in an action of contract, tort or otherwise, arising from, out of or in connection with the software or the use or other dealings in the software.
C4D材质禁用插件 Disable Materials 1.5:https://www.c4dcn.com/thread-37004.html
上一篇:C4D脚本 打孔脚本(MakeHole.CSC)
下一篇:OctaneRender_standalone_v2.0
学习学习学习学习学习学习学习学习学习学习学习学习
2015-3-25 11:44
2015-3-27 14:28
顶楼主啦..希望楼主多发精品好帖啦.....
2015-4-1 12:36
2015-7-30 16:13
2015-8-11 09:27
2015-9-9 11:31
2016-5-11 09:15
C4D插件汉化,就上C4DCN.com 专注C4D资源分享
2016-5-16 15:32
谢谢   DisableMaterials灯光检测插件
2016-8-24 08:22
