C4D卡通袖珍可爱小型机器人模型
根据程序输入模式,工业机器人可以分为程序输入类型和示教输入类型。编程输入类型是通过RS-232串行端口或以太网将计算机上的操作程序文件传输到机器人控制柜。示教输入类型的示教方法有两种:一种是操作员使用手动控制器(示教控制盒)将命令信号传输到驱动系统,以便执行器可以根据所需的动作顺序和轨迹执行一次;另一种是操作员直接带领执行器根据所需的动作顺序和轨迹执行操作。在教学过程中,工作程序的信息会自动存储在程序存储器中。当机器人自动工作时,控制系统从程序存储器中检测相应的信息,并将命令信号传输到驱动机构,以便执行机构可以再现各种教学动作。教学输入程序的工业机器人称为教学复制工业机器人。
According to the program input mode, industrial robots can be divided into programming input type and teaching input type. The programming input type is to transmit the operation program files on the computer to the robot control cabinet through RS-232 serial port or Ethernet. There are two teaching methods of the teaching input type: one is that the operator transmits the command signal to the driving system by using the manual controller (teaching control box), so that the actuator can perform once according to the required action sequence and trajectory; the other is that the operator directly leads the actuator to perform it according to the required action sequence and trajectory. During the teaching process, the information of the working program is automatically stored in the program memory. When the robot works automatically, the control system detects the corresponding information from the program memory and transmits the command signal to the driving mechanism, so that the executive mechanism can reproduce various actions of teaching. The industrial robot of teaching input program is called teaching reproduction industrial robot.
