C4D皮革表带高端男士商务手表模型手表的生产和生产基于一种简单而机智的发明,即所谓的“发条”。 它可以收紧和储存能量,并缓慢释放能量,以提升手表中的操作装置和指针,以达到显示时间的功能。 手表中的弹簧装置称为主弹簧。 手表的结构由头和表带(带扣)组成。 其中,头部包括:机芯,表壳,底盖,镜子,文字(通常称为表盘),指针,手柄(也根据时间而定)和顺序(对手表的要求部分)
The production and production of watches are based on a simple and witty invention, which is called "spring". It can tighten and store energy, and slowly release the energy to promote the operation device and pointer in the watch to achieve the function of displaying time. The spring device in the watch is called the main spring. The structure of a watch is composed of a head and a watch strap (buckle). Among them, the head parts include: movement, watch case, bottom cover, mirror, literal (often said dial), pointer, handle (also called according to the time) and order (part of the watch requirements)
