Modo软件Vray渲染器材质全面教程
它包含视频教程的两个部分,介绍了如何以Modo方式使用Vray渲染,重点介绍了材质制作和渲染设置
In this training you will go into more in-depth material creation, using both the Shader Tree and the Schematic view. The creation of coated materials using the Schematic is demonstrated, giving a good understanding of Vray's Blend Material. There are step-by-step examples demonstrating how to create a layered material using Vray's own procedural textures, and a practical example of Vray's Tri-Planar projection in use. These techniques will allow you to quickly build complex shaders using Vray native materials and textures, with a range of options that are powerful and flexible.
