C4D二战战争废墟城市游戏场景模型包
这是被摧毁的大城市的非常准确的场景。 根据华沙遗址的照片(1939年和1945年被德国人炸毁并焚毁)。
但是,场景结构和建筑物是唯一的,因此您可以用其他样式对其进行重新排列。
有47种类型的建筑物以及具有不同纹理的副本,背景中有15种低多边形,约有60个小元素(瓦砾,被破坏的墙壁等)
由于细节和高分辨率纹理适合高分辨率渲染和HD动画。
不用于细分的网格,使用了ngons。 优化和清晰的几何图形,视口中的场景非常明亮。
This is very accurate scene of big destroyed city. Based on photos of ruined Warsaw (bombed and burned by German in 1939 and 1945).
However, scene construction and buildings are uniqe so you can rearange it in other style.
There are 47 types of buildings plus copies with different textures, 15 low poly on background and around 60 small elements (rubble, destroyed walls etc.)
Because of details and high resolution textures suitable for hi-res renders and HD animations.
Mesh not intended for subdivision, ngons used. Optimized and clear geometry, scene is very light in viewport.
