C4D教程-在Octane Render中更快地渲染 - 菜鸟C4D
 热度: 66 [ 复制链接 ]
首页 › 分类资源 › C4D教程 发布时间:2021-2-1 15:03 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
3407
68
今天,我们将学习如何在Octane Render中更快地渲染。 我们将研究几种可用于在Octane Renderer中获得更快渲染的技术。
Choose the right Kernel
Lower the Samples
GI Clamp
Optimize your Geometry
Remove unnecessary objects and materials
Limit those Lights
Slow Material Types
Displacements
Texture Map Size
Dynamics
HDRI
AI Denoiser
Adaptive sampling
If you have VRam to spare
The Direct Lighting Kernel is the fastest kernel but it’s not as physically accurate as the Pathtracing or PMC method, use it if you can! The PMC method is the slowest to render – we never use it unless we are trying to create caustic effects – but it is always much slower.
Lower the Samples
Choose the minimum sample value that gives you an acceptable level of noise/ grain. If you use with the AI Denoiser you can take it very low, even to 300 in some cases. Higher values will keep fine details but render more slowly.
GI Clamp
Too high a value will give you fireflies (which can need A LOT of samples to clean up) – bring this value down to 1-10 and it should clean most of the fireflies up
The less geometry the faster the render! 3D scanned models are notoriously huge! Retopologize if you can.
If it’s not visible in the shot (or in reflections/refractions) get rid of it! Everything eats up VRam!
Limit those Lights
Limit the amount of lights in your scene to only what is necessary. Light materials (Blackbody and Texture Emission materials render even slower – try to limit these)
Slow Material Types
Specular Material Types are the slowest to render (Like Glass or Liquid) especially if you are using a Medium (subsurface scattering) if it’s not necessary – replace it with a more simple material like Diffuse or Glossy.
Displacements
Octane handles Displacements very well but they can still slow your renders – especially large 32bit images – if you can get away with Normal or Bump maps instead, do it!
Texture Map Size
8bit images render faster than 32 bit images and use less VRam – if you can sacrifice detail use smaller images!
Dynamics
Bake those simulations! Otherwise those extra calculations will slow you down!
HDRI
If you can replace your Area Lights with a HDRI map – do it! HDRI lighting renders MUCH faster!
AI Denoiser
You can use the AI Denoiser to clean up that sample noise which will let you lower the sample count way down! Doing this will speed up your renders dramatically! Don’t over do it though, especially for animation – you can get flickering and loss of detail if the samples are too low!
Adaptive sampling
Can render the less detailed areas of a scene super quick by turning pixels off when they reach a defined sample threshold. Don’t go too crazy with this or you’ll end up with noisy images.
Increase your Parallel Samples and Max Tile Samples
上一篇:CINEMA 4D超写实铁锈污渍效果场景制作渲染
下一篇:C4D塑料糖果包装建模材质动画渲染教程
2021-2-2 09:08
2021-2-2 09:09
2021-2-2 11:24
最全面的C4D资源网站尽在[C4DCN.com]!
2021-2-3 07:28
非常不错的学习资源,感谢楼主分享.
2021-2-3 08:58
2021-2-3 14:39
2021-2-6 11:11
2021-2-8 16:24
2021-2-10 14:44
