C4D 二维卡通风格动画训练教程How to Morph Between Splines in Cinema 4D - 菜鸟C4D
 热度: 73 [ 复制链接 ]
首页 › 分类资源 › C4D教程 发布时间:2015-4-11 17:34 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
4662
74
In this tutorial I’m going to show you a really cool workflow for morphing between splines using Cinema 4D.  This kind of spline morphing animation is awesome for using in conjunction your 2D workflow in After Effects by applying a Cel Shader material to your splines.  The nice thing about using the Cel Shader or just flat colors in the Luminance channel of your material is that when you use Cineware, these type of scenes render out super fast as a Cineware layer in After Effects because you’re not doing heavy shadow or shading calculations.  So to begin, I’ll go over the thinking behind the method I chose and how to achieve a nice, smooth spline morph.  Then, I’ll show you how I build a spline that is able to be affected by effectors to morph from one spline shape to another.  I’ll demonstrate how to use the Inheritance Effector to achieve this morph and ways to make your morph look super sexy and bouncy!  Finally, I’ll show you an alternate method of using MoSplines to morph and the shortcomings of going that route.
Here’s one of my previous tutorials that shows you how to create the 2D illustrative materials using the Cel Shader that I’m using for the objects in this tutorial:
上一篇:C4D 二维卡通风格动画训练教程Using the Pose Morph Tag to Morph Between Objects...
下一篇:C4D耐克LOGO线描演绎教程 Quick Tip Sewing Threads Effect
2015-4-11 20:42
其实我一直觉得楼主的品味不错!呵呵
2015-4-12 00:37
这个效果太有意思了。
2015-4-12 14:04
咱网站资源太棒啦!C4DCN.com真好!
2015-4-12 15:57
大神威武,真的很威武 ,还不够呀
2015-4-13 08:47
好可爱的字体~谢谢分享
2015-4-13 14:25
其实我一直觉得楼主的品味不错!呵呵
2015-4-13 17:08
顶楼主啦..希望楼主多发精品好帖啦.....
2015-4-15 15:19
这个效果太有意思了。
2015-4-16 13:03
