C4D快速遮罩插件Quick Matte Pro for Cinema 4D v0.9版本 - 菜鸟C4D
 热度: 59 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2015-4-28 10:29 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
7269
59
What is it?Quick Matte Pro is a brand new plug-in that I teamed up with an amazing plug-in developer, AJ Haines, on that is essential for an optimized and fast workflow and will change the way you work in Cinema 4D!  Quick Matte Pro has been designed to take care of all your matting & object buffer needs quickly and efficiently without having to worry about all the setup!  Set your mattes, add object buffers, and add every single object buffer in your scene to your multipass render settings with just a single click!
Quick Matte Pro v1.1 Updates:
-added docking support
-added R13 support
-added “incremental buffer” checkbox (Object Buffer tab)
-fixed issues with the Fracture Object
-stability fixes
-Now works with German version of C4D
-UNLIMITED OBJECT BUFFERS!
Add Mattes With a Click of a Button
Using the Quick Matte tag you just select the objects you want to be matted and hit “Add To Matte“. Simple as that. No need to deal with object buffers and multi passes. The other great thing is that it will render the matte as the RGB which will render very fast.  Click the “Preview Matte” button to have a live preview of what your matte will look like in your viewport!
Add Material & Texture Based Mattes
By choosing the “Texture” or “Material” option, you can select a material in the material manager or a Texture Tag and it will make a matte on all objects that use that material or those selected Texture Tag.  Think about that!  Material based mattes!  Want to composite a glow on say, any object that has an LED texture?  You can easily do that with the Material based Mattes option.
Add/Remove Object Buffers with a Single Button Click
“Add To Buffer” will add a compositing tag to any objects you have selected if it doesn’t already have one and turns on the object buffer number that corresponds to the number you have set in the “Buffer #“.  By hitting the “Preview Buffer” button you can get a LIVE preview of what your buffer pass will look like right in your viewport!
“Remove From Buffer” will just disable the object buffer in the compositing tag that corresponds to the number in the “Buffer #“
Add/Remove Buffers to Multipass with a Single Click
Know how much of a pain it is to one by one add object buffers to your multipass render settings?  No more carpal tunnel clicking like crazy to add object buffer after object buffer!  With Quick Matte you can add an UNLIMITED amount of Object Buffers in your scene to Multipass render settings with a single click!
“Add Buffers To Multipass” finds all active buffer numbers and adds them to your mulitpass in render settings.
“Remove All Multipass” removes only object buffers created by this plugin.
Version Compatibility
Quick Matte Pro requires Cinema 4D R13 (Broadcast or Studio version) and above.
此为0.9版本,现在插件最新版为v1.1 PRO专业版售价24美元
上一篇:C4D预设 Renderking - Vray灯光预设 Lighting Essentials for Cinema 4D
下一篇:旋转目标摄像机脚本预设 V1.0
碉堡了  赶紧下来用!!!谢谢楼主!
2015-4-28 10:34
咱网站资源太棒啦!C4DCN.com真好!
2015-4-28 10:36
谢谢楼主分享C4D快速遮罩插件Quick Matte Pro,不知道是否FREE?
2015-4-29 08:27
怎么个用法?谢谢分享了
2015-5-4 17:12
谢谢分享C4D快速遮罩插件很有意思的插件,
2015-5-5 16:11
顶楼主啦..希望楼主多发精品好帖啦.....
2015-5-8 09:32
2015-5-17 18:20
谢谢分享了呀!!!!!!!!!!!!
2015-5-20 20:54
好东西非常棒!谢谢楼主的分享!!!!!!!!
2015-5-26 10:48
