适合现代花花公子的美丽套装。然后在低于3.1的V-Ray版本中工作。注意,BRDF部分的材质是MicrofasetGTR(GGX),如果你的版本是3.1之前的,那么BRDF字段会是空的。选择Blinn、Phong或Ward-这对您来说更可取。
Beautiful set for a modern dandy.
then works in V-Ray version lower than 3.1. Be careful, the materials in the BRDF section are Microfaset GTR (GGX), if your version is older than 3.1, then the BRDF field will be empty. Choose Blinn, Phong or Ward - which is preferable for you.
