终结者T-600模型 terminator - 菜鸟C4D
 热度: 93 [ 复制链接 ]
首页 › 分类素材 › C4D模型 发布时间:2015-4-28 13:53 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
8194
93
This model is based on the T-600 terminator, HIGHLY detailed. Working hyraulics and cables, complete with high res maps for all body parts and weapon ranging from 1024x1024 to 4096x4096. Maps include Diffuse,Bump and Reflection maps for every body part.HDR image is included. With VRAY the file will render exactly as seen in pictures. File only comes with Vray materials. But all textures (jpeg) can easly be incorperated into any renderer to get similer results.eg(mental Ray, Brazil, Maxwell.)
Downloading as an OBJ or FBX can mean you can use this model in any 3D software.
This model is fully rigged using the standard 3DS Max BIPED. Making animating childs play. Ammo chain is controled with IK spline This is by far the most realistic T-600 availble. Please download preview pictures for better view of fine details.
Caution!! Because of the high quality and high number of maps (jpegs) this model can be memory hungry. So included is the scene as you see it here, also the same scene with out the materials applied, 3DS MAX 2009 64bit recommended.
上一篇:终结者T-600头部模型terminator T-600 Head
下一篇:终结者Terminators机器人能量来源-fuelcell电池
哇~~~,这个厉害啊,全身的,太棒了!!!!
2015-4-29 00:35
谢谢分享!
2015-4-29 13:32
2016-6-29 22:26
传说升级到R12就可以使用快速回复,升级更快!
2016-8-21 17:12
2018-2-17 22:49
非常棒!希望楼主能分享更棒的资源出来。
2018-3-24 20:58
2018-3-29 09:37
2018-5-4 08:41
2018-5-10 14:09
