遗传效应可能是一个最被低估的和未充分利用的效应在执行菜单-它可能是玩弄我喜欢的效应之一!在本教程中,我将告诉你如何轻松地创建粒子模拟的形态类型的动画只使用Mograph模块,效应,和动力学。结合使用超级强大的遗传效应和其他的MoGraph效应和变形,可以实现接近相同的效果作为发射极,思维粒子,或X-粒子在你正常的工作流程的一个简单的替代而无需触摸XPresso或者学习一些新的粒子系统或购买插件。 课程名称:C4D继承效果器制作粒子汇聚效果教程Creating a Particle Morph Using Cinema 4D’s...
知识点:运动图形教程、效果器教程、粒子教程、继承效果器、汇聚模型教程、粒子汇聚、插件、变形 C4D教程
教程方向:默认粒子、运动图形
授课语言:英文
工程素材:无
渲染插件:自带标准
下载权限:VIP精选 The Inheritance Effector is probably one of the most underrated and underutilized effectors in the effector menu - and it's probably one of my favorite effectors to mess around with! In this tutorial, I'll show you how you can easily create particle simulation morph-type animations using only the Mograph Module, Effectors, and Dynamics. Using a combination of the super powerful Inheritance Effector and other Mograph Effectors and Deformers, you can achieve close to the same effect as an Emitter, Thinking Particles, or X-Particles as a simpler alternative in your normal workflow without having to touch Xpresso or learn some new particle system or buy plug-ins. |
