texMATE - 菜鸟C4D
首页 › 分类资源 › C4D插件 发布时间:2015-4-29 17:08 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
4051
37
texMATE Python Command Plugin, by tcastudios.com © 2012/14 AllRightsReserved
texMATE need Cinema4D version 15.057 to install.
NOTE: Separate download for earlier versions of Cinema4D
Free for use in your personal and commercial work.
texMATE comes 'as is' with no warranty nor free personal support.
The texMATE files may not
be re-distributed and/or
directly linked to in any form.
Always refer/link to:
for most current version.
texMATE v2.00   : First version.
- 1. INSTALL
- 2. OVERVIEW
- 3. SETTINGS
- 1. texMATE INSTALL.
texMATE needs CINEMA4D R15.057 to be installed.
Place or replace the unzipped "texMATE" folder into
the "plugins" folder in /user/preferences.
Found via Edit -> Preferences -> "Open Preferences Folder…"
Keep everything inside the "texMATE" folder as is for intended functionality!
As texMATE is a Command Plugin, you only need to install it in your Work station
as it is not used/needed for NET.
Start/re-start Cinema.
If prompted, re-start Cinema again for texMATE to register its settings.
The texMATE Command is then found in the Plugins Menu.
NOTE: texMATE includes a complementary "copyFROMCB.cof" COFFEE Plugin that texMATE
uses for copying bitmaps from the Content Browser. This 'texMATE_Helper' is greyed out in
the Plugins Menu and only run from within texMATE.
- 2. OVERVIEW:
texMATE copies all linked files from the document to a selected folder.
The files are the ones found in Project Settings -> Textures.
- 3. SETTINGS
There are no Settings for texMATE, you only run texMATE from the Plugin Menu.
You select a Collecting folder and all found files are copied into this folder.
texMATE information is printed in the Console (Scripts->Console)
NOTE: texMATE collects any texture even via Relative Paths.
If you might have several textures with the same name in your Global Paths settings,
you can re-link Relative Paths to Absolute Paths using pathMATE prior to extracting/
collecting the textures.
Cheers
Lennart Wåhlin - tcastudios
上一篇:旋转目标摄像机脚本预设 V1.0
下一篇:C4D插件 魔术合并插件MagicMerge
这个是怎么个用法?感谢分享~~~~~~
2015-5-27 01:46
谢谢分享!!!!!!!!!!!!!!!!
2015-9-7 20:52
好好看看,认真学学,谢谢楼主无私分享!!!!!!
2016-8-31 12:23
你不觉得我这红色的用户名是不是很高贵呢?!因为我是VIP
2016-8-31 13:51
2016-10-6 16:53
这个是怎么个用法?感谢分享~~~~~~
2016-11-20 00:56
好东西啊~感谢楼主,感谢感谢!!!
2017-6-7 13:01
感谢无私分享,谢谢,请问用法教程有么?
2017-8-8 21:08
哇,看着很厉害的样子呢,多谢分享··············
2017-11-15 16:13
1234下一页
