AE动画脚本下载包含教程 Aescripts TypeMonkey v1.14是一个MG脚本,语言为英文。支持after effects软件版本:CS4、CS5、CS5.5、CS6、CC,脚本使用教程:含教程。支持PC、MAC系统安装使用,下载检索码QL220217AC-33。当前ae插件素材由用户慧彩分享在AE插件区,更多关于动画、MG特效、运动脚本的ae脚本请访问菜鸟c4d网站!
AE Motion脚本 Aescripts TypeMonkey v1.14
不产生关键帧制作AE运动文字,相机等Motion动画,快速准确。下载包含脚本和7个官方高清视频教程。
Creates kinetic type + camera, dynamically linked to markers with no keyframes. Very fast & intuitive.
主要特征:
Creates random kinetic type layouts based on parameters entered into the control panel.
Keyframeless timeline makes changes to timing as simple as sliding a marker.
Creates a parented camera that points to each successive word as it transitions on.
Distributes words evenly over the length of the composition or work area.
Manual adjustments are easily made to size, position, rotation and opacity.
Features a wide range of type transitions randomly selected by default, but can be specified as well.
Marker Sync feature allows for push button alignment with preexisting marker layers, making syncing to music a breeze.
Allows for different interpolation for camera movement, auto rotate and auto frame.
Automatically builds and cleans to facilitate easy experimentation.
Now supports motion blur and preset load and save.
Kuler color palettes are now easily imported.
Support for 3rd party TextMods (sold separately), these can add support for Right to Left languages as well as other fun text modifications.
Check out the available TextMods: Arabic Text and Hebrew Text.
Free: Includes MonkeyTools- an ongoing collection of scripts specifically written to enhance the functionality of the Monkey Suite.
LayerMonkey vs TypeMonkey
So what’s the difference? The main difference is that TypeMonkey is custom built as a kinetic type generator. It’s a workhorse. All you have to do is enter your text into the Text Box and click Do It! It also allows you to switch between multiple layouts with a few simple key commands.
LayerMonkey can achieve similar results with text when using layered Illustrator files, but all those layers need to be prepared manually. For longer pieces that’s going to be a lot of work. However, if you want to use multiple fonts, LayerMonkey is the way to go because with TypeMonkey, those changes will need to be done manually by unlocking multiple text layers. And then theres the whole image part that LayerMonkey does that TypeMonkey is not equipped to do.
So which is better? Neither. They’re different. LayerMonkey is more flexible but requires more setup and TypeMonkey is fast and easy is but more limited. You just need to pick the right simian for the job…and in many jobs there’s a need for both.
