AE颜色管理选择脚本包含教程 Swatcher Scripts - 菜鸟C4D
首页 › 后期处理 › AE插件 发布时间:2022-2-23 11:02 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
1559
10
这是一个调色、其他脚本,语言为英文。支持after effects软件版本:CS4、CS5、CS5.5、CS6、CC,脚本使用教程:含教程。支持PC、MAC系统安装使用,下载检索码QL220217AC-42。当前ae插件素材由用户慧彩分享在AE插件区,更多关于视频教程、配好的、序列号、颜色、管理的ae脚本请访问菜鸟c4d网站!
AE颜色选取脚本 Swatcher – After Effects Scripts (Videohive)
AE的一个脚本,可以在Dribble,colourlovers,kuler等网站选取搭配好的颜色,同样的插件有Digital Juice的Color Rules,包含脚本和序列号,一个视频教程,使用前请先观看视频教程
Swatcher is a script for Adobe After Effects, loading color palettes from several services like the Dribbble(Full list you can find below).
You can also open a color palettes from files and keep it in your own swatch library.
What’s more, Swatcher allows easy colorize your compositions in a very convenient way.
Colorizer function finds each color in your selected layers, such as Solid Layers, Text and Shape Layers.
The Shape layers choosing for colorize each fills and strokes inside content parameter.
In the colorizer you can control each color on your scene
主要特性
Opening palettes from a file. Supported an .ase or .aco file formats
Editing: controlling the brightness, removing and sorting colors in a the Color swatch field.
Creating a dynamically main swatch in the composition and binding all colors to it.
Replacing all current assigned colors in the composition new palettes by one click.
Working with Swatch Library, where you can keep your own palettes.
Colorizer function, dynamically changing all colors of each selected layers, such as Text layers, Solid with Ramp or Fill effects and shape lay
上一篇:46组AE文字出入动画预设下载 Text Fx Generalist
下一篇:AE傻瓜快速跟踪脚本 Easily Stick 2D Layers
那个大神对c4d变形器熟悉啊,我遇到一个棘手的问题想求助大家
2022-2-23 11:18
C4D透明材质有没有窍门,渲染的时候自带渲染器太慢而且还发黑材质
2022-2-23 12:39
有没有好看的c4d飞机模型可以下载的,求推荐
2022-2-24 16:19
菜鸟牛逼大神太多了,只有我是菜鸟
2022-2-25 04:58
c4d噪波类型太多了,我还没有全部掌握
2022-2-26 11:24
慧彩楼主这个帖子实在太内涵,先赞一个!
2022-3-5 19:49
菜鸟C4D大神太多了。我这个小菜鸟什么时候也能成为大佬呢
2022-3-5 21:07
c4d立体字模型咱网站多不多
2022-3-5 22:12
c4d设计师都从事哪些职位啊?工资高不高呢
2022-3-6 02:33
