AE 64位调色监视器助手插件 qp Grade Assistant 2是一个调色插件,语言为英文。支持after effects软件版本:CS4、CS5、CS5.5、CS6、CC,插件使用教程:含教程。支持PC系统安装使用,下载检索码QL220217AC-47。当前ae插件素材由用户慧彩分享在AE插件区,更多关于视频教程、监视器、调色、监视助手的ae插件请访问菜鸟C4D网站!
调色监视器助手 Aescripts qp Grade Assistant 2
AE 64位插件,下载含插件和视频教程
Written completely from scratch as a native 64-bit plugin, qp Grade Assistant 2 provides the next generation of scopes and monitoring for compositing and grading in After Effects.
Key Features:
Five scopes:
Waveform monitor (Luma, and RGB views)
NEW! Vectorscope, including Hue Vectors graticule designed by grading guru Alexis Hurkman
Channel Parade (RGB and YCbCr views)
Slice Waveform (Luma, and RGB views)
NEW! Histogram (Luma, and RGB views)
Five monitor layouts:
Full-screen single
Four-way split
Four-way classic
Windowed (resize and move anywhere on screen)
Off (scopes only)
Fully customisable interface – use only the scopes you need for the job, and place them anywhere on screen
Three scope sampling levels – High (1:1), Medium (1:2) and Low (1:4) for optimum performance whatever your hardware
Alpha and Luma monitoring in the primary monitor; YCbCr monitoring added to four-way set-ups
Plus all the great features from the original plugin:
Compare with original (or alternative) layer
Gamma (and now Gain) controls for checking black and white levels
