AE表达式纠错检查脚本(含教程) pt_ExpressEdit 2.1 - 菜鸟C4D
首页 › 后期处理 › AE插件 发布时间:2022-2-23 21:45 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
1501
10
这是一个其他脚本,语言为英文。支持after effects软件版本:CS4、CS5、CS5.5、CS6、CC,脚本使用教程:含教程。支持PC系统安装使用,下载检索码QL220217AC-50。当前ae插件素材由用户慧彩分享在AE插件区,更多关于视频教程、表达式、纠错、检查脚本的ae脚本请访问菜鸟C4D网站!
AE表达式查错修改脚本 Aescripts pt_ExpressEdit 2.1 +教程
Aescripts pt_ExpressEdit 2可以查找,应用和编辑修改AE工程中使用的表达式,也可以查找工程表达式出现错误的地方并且自动修复。下载包含脚本和视频教程
Search, apply and edit expressions throughout your project. Expressions can be saved, or instantly applied to one or more properties. It can also check for broken expressions, re-enabling them automatically where possible.
使用教程文字版:
SEARCH: Use the search options to specify which expressions you’re looking for. Click the Search button to scan your project for expressions based on your search criteria.
FETCH: With Auto Fetch enabled, when you select an expression from the list it will appear in the text edit box ready for editing. When Auto Fetch is off, use the Fetch button to get the selected expression into the edit box. Select a property in your comp instead of the list to fetch the expression from there.
APPLY: Edit the expression in the text edit box, then hit the Apply button to apply it to any properties selected in the list. Note: You’ll need to use Ctrl-Return to get a line return in the text edit box.
ADD TO TIMELINE: Use this button to add the expression to any selected properties in the Timeline. This is useful if you want to add expressions to properties that don’t already have ones applied. You’ll need to do a new search for any newly added expressions to appear in the list.
AUTO TEST: With Auto Test enabled the script tests expressions during a search to ensure they are valid, revealing new errors or re-enabling them if previous errors are fixed. If you do something that breaks your expressions you can just Undo then run a search to re-enable them. While this option is recommended, you can turn it off if you want to do searches that won’t affect the result.
ACTIONS: Use the actions/preset pulldown to enabled, disable or remove any selected expressions. Use Refresh List if you’ve made any changes and want to update the list. Use Test Expressions to check the expressions are valid.
PRESETS: With an expression in the text edit box, click the Save button to save it as a preset. Select previously saved expressions from the bottom of the action/preset pulldown, then click Apply to add them to any properties selected in the list.
上一篇:AE运动图形MG必备脚本(含教程) Ouroboros
下一篇:AE+PRR插件合集 EVisionFX支持CS6-CC WIN+MAC系统
发现好的AE插件十分不容易,尤其是楼主分享的干货更得顶了!
2022-2-23 22:16
楼主能不能多分享点AE插件跪谢!
2022-2-23 22:35
跪求好心人分享c4d片头一个!
2022-2-24 02:05
在下流行元素前来膜拜慧彩大神,还请不要笑话
2022-2-24 02:05
必须顶啊菜鸟C4D真的是一个非常好用的素材网站!
2022-2-24 08:11
想问一下C4D材质球下载在哪里?我怎么没找到啊谁告诉我呗
2022-3-5 19:16
楼主好人,今天的AE插件确实不错!收藏了
2022-3-5 19:30
2022-3-7 05:00
在线等!在线等c4d手模型用来做动画~
2022-3-7 15:38
