AE智能剪辑脚本 The Edit Detector v2.56 - 菜鸟C4D
首页 › 后期处理 › AE插件 发布时间:2022-2-26 00:23 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
1410
10
这是一个其他脚本,语言为英文。支持after effects软件版本:CS4、CS5、CS5.5、CS6、CC,脚本使用教程:含教程。支持PC、MAC系统安装使用,下载检索码QL220217AC-69。当前ae插件素材由用户慧彩分享在AE插件区,更多关于智能脚本、剪辑、自动检测、镜头切换、单独视频的ae脚本请访问菜鸟C4D网站!
AE素材自动剪辑脚本 Aescripts Magnum – The Edit Detector v2.56
自动检测视频素材中镜头的切换,然后把每个镜头剪辑成单独的视频,下载包含脚本和视频教程
Automatically detects edits in footage. To use it you simply select a footage layer in a comp, set the work area to the region you’d like to find edits and tell Magnum to go to work!
剪辑之后我们可以使用下面几个功能:
Split into new layers: This mode will split the selected layer into individual layers at every edit.
Trimmed pre-comps: This mode will split the layer and then pre-comp it into a comp that is the length of the split layer.
Full-length pre-comps:  This mode will split the layer and pre-comp it into a comp that is the same length as the original comp.
Trimmed adjustment layers: This mode will create a new adjustment layer that is trimmed to the length of every detected scene.
Place markers on layer: This mode will create and place markers at every detected edit point.
Save thumbnails for each cut/marker: This mode will export a thumbnail for the selected layers or or all layers if none is selected. If you add a text layer named: slate it will burn it into each thumbnail. All special keywords work here as well. Position and style your text before running the export. If you add a text file named: export_template.txt in the export folder it will use it to create an export report file.
Again special keywords work here and if you use tabs or commas it will be a spreadsheet. Replace ‘layer’ with ‘marker’ in the keywords when exporting thumbnails from markers. Thumbnail size will match the comp resolution.
上一篇:AE+PR渲染输出脚本 FanDev CuteDCP v1.7.5
下一篇:AE柔和真实阴影灯光环境脚本(含教程) BR Illumination V1.01
大神,C4D这么多渲染器那个最强啊
2022-2-26 00:23
最近项目需要C4D人物模型,最好是带骨骼绑定的,谁分享点啊?
2022-2-26 21:35
渲染材质真的是个技术活太费脑子了,谁叫我不会呢
2022-2-27 05:00
好厉害!大神啊,终于找到想要的C4D素材了,感激不尽
2022-2-27 13:35
Octane渲染器插件谁有最新的汉化版啊,我这没有中文的插件,好心人分享我一下吧
2022-2-27 20:54
加油! 越来越厉害了!技术见长啊,欢迎新作品继续分享给大家欣赏
2022-3-5 22:12
希望版主大大多更新点AE插件资源吧,工作中需要用到~
2022-3-6 02:34
C4D建模有好多问题,比如多边形重复总是调节不好点,该怎么办呢
2022-3-6 02:34
想精通c4d多通道渲染,看来还是得继续多看教程多练习啊,撤了继续研究cinema4d去
2022-3-6 06:46
